2000 Trans Am 24,000
Old 08-24-2008, 10:14 AM
QuickSilverTA's Avatar
Default 2000 Trans Am 24,000
Give me idea what it's worth.
Photos
http://www.flickr.com/photos/quicksi...31029369/show/
About 2,000 miles on the motor, just had the rearend rebuilt.
Engine
• Forged 347
• Diamond Forged 10cc Pistons
• Diamond 4130 Chromemoly Wrist pins
• Diamond Proselect Ring Set / FILE FIT
• Federal Mogul 152M Main Bearings
• Blueprinted & Balanced
• Callies I-beam LS1 rods
• ARP Head Studs
• ARP Main Studs
• APR 2000 Rod bolts
• Polished & Magnafluxed Stock Crank
• 2004 LS6 block
• Morel Lifters
• Stock Rockers with aftermarket bearings
• Fluidampr Harmonic Damper
• Comp Cams Hardened Pushrods
• Double Roller Rollermaster JWIS Timing Chain Nitrated Gears
• Prothance Motor Mounts
• Comp Cams 234/236 .598/.601 112+2
Heads
• AFR 225cc 72cc heads
• Flat milled to 71cc
• Comp 921 springs
• SS Sodium filled intake valves
• SS exhaust valves
• Cometic Head Gaskets
Intake
• FAST 90mm Intake
• Nick Williams 90mm Billet Throttle Body
• Texas Speed & Performance Induction Lid
Exhaust
• Hooker Catback
• KOOKS 1 Ύ to 1 7/8 LT headers
• KOOK off-road y-pipe
• Flowtech Cutout in I-pipe
• All clamps SS Band Clamps
Fuel
• Nasty Fuel Rails
• Racetronix Delphi/Lucas 37# High Impedence Fuel Injectors
Drivetrain
Moser 12 bolt rearend
• 33 Spline Axles
• Gundrilled Axles
• Star Flanges
• ABS
• 4.10 Gears
• TA Cover
• 1350 Yoke
• Denny’s Nitrous Ready Driveshaft
Transmission
• Stock GM T56
• RAM 910 Clutch
• RAM 402 Pressure Plate
• RAM 1550 Billet Steel Flywheel
• ARP Flywheel Bolts
• ARP Pressure Plate Bolts
• Pro 5.0 Shifter with shorten handle
Suspension
• LG Motersports Adjustable Rear Control Arms
• LG Motersports Adjustable Panhard Rod
• KONI SA shocks all around
• Suspension Technique Sway Bars, front and rear
• Intrax 2 inch lowing springs
Exterior
• Boyd Coddington Timeless Wheels
• Rear Silver Collectors Edition filler
• Polished Rear and Front Calipers
• Factory GM Ram Air Hood
