removing stripped screw in wheel studs.
how's it done? it unscrews to the point of the stripped part, but I DO NOT want to strip the axles removing them...what are my options?
I let a "friend" put the lugs on the back while I did the front and he cross threaded 2 on the driver side, and 1 on the passenger.
ordered new ARP studs, and Mcguard lugs.
Chad
Chad
LS1Tech Co-Founder
Are they factory studs? If so, just loosen them until they do not turn any more and then put a big breaker bar on them and crank them to bust them off. Replace them once you get the wheel off.
Other than that, you may have to use a nut splitter tool to crack the lug nut open and get it off the stud.
I prefer busting them, it is quick and the stud is ruined anyways.
Chad
