Tire rim combo questions(help)
Old 01-29-2009, 06:59 PM
chadeburton's Avatar
Question Tire rim combo questions(help)
I have a 2002 ta and i just bought the oe creations zo-6 19" rims. They are 19"x10"wide with a +56 offset. I plan to run 275 width tires on front. The problem is i am having a hard time finding the perfect rear tire. I want to go a little wider but i'm not sure a 305 will fit on 10" wide rim. Also nhow high can i go?? Found a couple tires 295/35-19 but they are 27" tall. Also nitto has a 305/30-19 but i'm still worried about putting the 305s on a 10" rim. Can someone out there give me some help? Thanks
Old 01-30-2009, 12:35 AM
gc302047's Avatar
305 is the biggest you can go for sure dont go any bigger some people put 315s on a 10 but dont do that you would be pushing your luck
295 and 305 tires are your best bet
i think the nittos run thinner than what they say but not sure. get on nittos website and see if you can find any info on there tire
but any other tire get a 295 or 305
Old 01-30-2009, 03:38 AM
whtnuklz's Avatar
I started a thread the other day and asked the question about putting a 305/30-19 onto a 19X10. what I've found is the 305 will be fine on a 10" wide wheel. I also called a few tires shops and they said it will fit fine but 305 is the max for 10" wide wheels.
