What would it take to make this work?
Specs on wheels I'm wanting -
Front Wheel Diameter (inches): 19
Front Wheel Width (inches): 8.5
Front Offset (mm): 30
Rear Wheel Diameter (inches): 19
Rear Wheel Width (inches): 10
Rear Offset (mm): 37
Bolt Pattern (PCD): 5x120
Wheel Hub Bore (mm): 72.6
Now I believe if I got a spacer for the fronts I'd be good for the offset. Don't know if I'd need longer studs then? The backs I believe will work. Now the other thing I was unsure about is the hub bore. I know ours is 70.3mm so would I need hub centric rings? Thanks to anyone for the help.
