Will new tire fit
Old 03-11-2009, 07:10 PM
Tee1up's Avatar
Default Will new tire fit
I have MT 275\60\15 but plan to change to 325\60\15
Will they fit without modifacation.
Old 03-12-2009, 12:40 AM
alharbi's Avatar
first , i doubt there is a tire with 325/60/15 ----> i think you mean the 315/60/15 or 325/50/15
if you mean the the 315/60/15 , Minimum Recommended Rim Width (in) is 8.50 in. and the Maximum Recommended Rim Width (in) will be 11.00 in.
and if you are lookin to the 325/50/15 , Minimum Recommended Rim Width (in) will be 9.00 in. and the Maximum Recommended Rim Width (in) will be 12.00 in.
i'm talking about the M/T street radial
i'm not sure if they will direct fit without modefications
Old 03-12-2009, 01:26 AM
Slash8915's Avatar
You can fit a 315 on a 8.5" wheel??! Man... I have 10" wheels, and I thought 305's were pushing it...
Old 03-12-2009, 01:35 AM
Magic Man's Avatar
I just looked up on Summit and it says 315 will go on 8.5-11" rim.
Old 03-12-2009, 10:10 AM
Mike in LA's Avatar
I'm pretty sure that the size of the side wall has a lot to do with what will work and what won't work.
Old 03-12-2009, 07:01 PM
Bullet95z28's Avatar
the 315 will fit on a 15x8.5 wheel, due to a taller sidewall, but not if its like a 17" wheel, then you would need a wider wheel like 10" or 11" due to a shorter sidwall.
