Torque Thrust M's, need help with fitment?
Old 03-17-2009, 10:24 PM
Travis_68's Avatar
Default Torque Thrust M's, need help with fitment?
I am looking at a set of wheels and tires, and I am unsure if they will fit on my car. My car is a 95 T/A, M6, with t-tops. It isn't lowered or anything like that. The wheels are a set of Torque Thurst M's. Here are the specs on the wheels.
TIRE SIZE: FRONT - 255/45ZR17
REAR - 285/40ZR17
THE FRONT WHEELS ARE 17X9, OFFSET +45mm, BACKSPACE 6.77"
THE REAR WHEELS ARE 17X10.5, OFFSET +44mm, BACKSPACE 7.48"
THEY HAVE 5X4.75 LUG SPACING.
Any help with this would be great. I read about the 17x11 rims with the 50mm offset, and some of the problems that are associtated with that wide of a rim. Will this rims just be able to bolt on with those tires?
Thanks,
Travis
Old 03-17-2009, 11:41 PM
kjmusic01's Avatar
Default Wheels
Hi, perfect fit. The only thing I would do different is go with a 275/40/17 tire in the front. I just mounted these on my 95 camaro Z/28 and they look great! Thats the correct back spacing and offset 45m front and 44 rear bolt pattern 4.75 Good Luck I hope this helps.
Russ
Old 03-17-2009, 11:44 PM
kjmusic01's Avatar
Default Wheels
Travis, these will bolt right on. I had 11's in the rear no problem either with the torq thrust II's but didn't care for the look. Good decision.
Russ
Old 03-18-2009, 07:11 AM
Travis_68's Avatar
thanks for the info. I was looking at the Torque Thrust M's, and also the American Racing 200s. They are all 4 17x9.5 and have 275 tires all around. I just have to decide which ones look better. I know the torque thrust wheels look good, but I have never seen the other ones in person, just pictures.
Old 03-18-2009, 09:02 AM
udienow's Avatar
For those wheels I would go with 275/40/17 front tires and 315/35/17 rear tires...
