noob question
Old 04-20-2009, 05:03 AM
therobman's Avatar
Default noob question
i have 315's and im lowered andx they rub a decent amount im going to roll the fenders but what is the bfh mod and how exactly will it help?
Old 04-20-2009, 05:52 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
BFH-Big F*cking Hammer. It is used to clearance the front portion of the inner fenderwell
Check out this link, it's a pretty good write up
http://www.ls1.com/forums/showthread...t=hammer+wheel
Old 04-20-2009, 06:05 AM
RiceEaterZ's Avatar
yep thats the one, Big ******* Hammer. You'll wanna use that to move the inside fender area in a bit since the 315's are most likely rubbing on the inner fender on the edge of the tire and /or bumpstop, rolling them along with the BFH Mod should do wonders, may need to angle grind the bumpstops,last resort run some small spacers. That ought to do it
*just went through all of this, I'm sure yours is worse since I'm not lowered yet*
Goodluck with your project I painted my calipers while I was in there
