17x9.5 with 6.5" B.S. for rear only?
I am looking at the centerline Lazer and the only B.S. for a 17x9.5 is 6.5". I would only run these in the back with a 275/40/17 Nitto DR on it. I know the typical is to do a 7" B.S., but will the 6.5" fit? Also, I do not mind if I have to roll the lip a bit. The way I read it, a 17x11 with a 7.75" offset will have 3.25" to front of wheel and a 17x9.5 with a 6.5" offset will only have 3" to front, which if I am understanding correctly, means my 6.5" B.S. should be inset 1/4" more than a typical 17x11.
On the front I would run a 17x8 with 5.5" B.S. and a 245/45/17 Nitto 555 tire.
Let me know what ya'll think about this.
James
James
6.5" is as high as it goes. But if you do the math (as I understand it) you get a +45mm offset with a 6.5" B.S. on a 9.5" rim.
I have read the sticky and have tried to find other posts, but I am really looking for a pic or someone who has done this setup before, not speculation or opinion, although i do respect the opinion and I agree....I would go with a 7" B.S. if it were available.
I know I've just got to be doing something wrong with the Math...can someone tell me were I'm not understanding?
It seems like they should fit, but I don't wanna order them and it be wrong.
It seems to me that these wheels should basically stick out 1" farther than a stock 17x9 with 7" B.S., right?
