Will this fit my camaro?
17” Profil 5 Spoke F614A02-1574
Outer Rim 1.5 X 17
Inner Rim 7.5 X 17
Front = 9.0 X 17, +44.5mm offset
18” Profil 5 Spoke F714A02-1674
Outer Rim 2.0 X 28 30 Hole
Inner Rim 8.0 X 18 30 Hole
Rear = 10.0 X 18 , +44.5mm offset
Its a set of fikse wheels for a corvette. Wondering how they would fit on a camaro. Thanks
Outer Rim 1.5 X 17
Inner Rim 7.5 X 17
This HAS to stop... Learn it. Know it. Live it.
https://ls1tech.com/forums/wheels-ti...must-read.html
Yea thanks for that. I definently looked at that first. I know it will fit and is within the "will fit" range on the backspacing. Let me re-phrase my question... Will this look right? Next time just answer the question instead of trying to be a hardass. According to that chart it will but everyone else who is running that wheel has a different backspacing. Was wondering if anyone has actually ran a wheel specifically setup for a vette on a camaro and was it noticable it wasn't designed for that car. Thanks
You asked a dumb question, so you will get reamed for it. It's only fuking 2009, I'm almost positive you're the only one since 1997 who has thought about putting Corvette wheels on an F body! Will it look right? jesus christ!!! convert MM to inches and you'll see that among the stock F car offset 0f 50mm, the Fikse Camaro offset of 38mm and this sets 44mm is approx a whopping range of ONE HALF INCH!!! This board is getting almost as bad a thirdgen.org. Next, are you going to ask to see if anyone has pics of these wheels on a white SS, because you know, if its pictured on a navy blue plain Camaro that just won't do. How's that for "hardass"?
sorry ls1tech.
