Even more confused - Help needed
I've read and re-read all the info but I'm no closer to understanding. Please dont think I'm being lazy, I have tried to work the sizes out.
OK, rather than try and guess what rims and tires will fit, I have found a supplier who G'tees the following to fit without any modifications.
Wheel Sizes:
(2) 18x8.5" (Fronts)
(2) 18x10.5" (Rears)
Lug Pattern:
5x4.75" (same as 5x120.65mm)
Offsets:
18x8.5" wheels: +56mm offset (6.95" back spacing)
18x10.5" wheels: +58mm (8.00" back spacing)
Center Bore:
70.3mm
Tires Nitto NT555
(2) 245/40ZR18 (Fronts)
(2) 285/35ZR18 or 295/35ZR18 (Rears)
My car has been lowered 1.5" (Eibach)
My brain is totally swiss cheesed about all this, so before I take the plunge, as I have to import into the UK, I hope someone will help me out. If you need any more info please ask.
Thanks in advance guys.
Wheel Sizes:
Lug Pattern:
Offsets:
Center Bore:
70.3mm
Tires Nitto NT555
Thank you for taking the time to answer my question, I feel better now knowing that they will fit. Already emailed the supplier for a quote. Thanks again.
Yes they will definitely fit. But like xsta said, with 295+ you will have to either use spacers, or do the bfh mod. I would just go with spacers and new wheel studs. Here's a coupla pics of my car with and without spacers on back. My rear tires are 295/35/18
Without:
With:
Hope this helps.
Without:
With:
Hope this helps.
Hope this helps.
Hope this helps.
Your wheels look similar to the ones I'm thinking off.
Thanks again.
