All f-bodys with billet specialties.
trying to decide whether i want to buy some for my car. i know about the search button, but this is easier. thanks
Heres mine 15x3.5 in the front with 1-3/4 backspacing runing a 7/32 spacer with 3/4 long sst shank so it goes thru the spacer for more lug bite and 15x10 with a 5.5 backspacing for my home built rear heres the link if you want to check it out https://ls1tech.com/forums/gears-axl...8-8-build.html
Heres mine 15x3.5 in the front with 1-3/4 backspacing runing a 7/32 spacer with 3/4 long sst shank so it goes thru the spacer for more lug bite and 15x10 with a 5.5 backspacing for my home built rear heres the link if you wat to check it out https://ls1tech.com/forums/gears-axl...8-8-build.html
Do you think this would work with 17x11's out back. Also where would I get some 17" Billet Specialties with out getting screwed over. Also with a 17x11 on a rearend that is 4" more narrow the bs on the rears would be more like 5" back space..... right or wrong?
