bogarts and hoosier qtp question
Old 09-09-2009, 09:37 PM
1fstSS's Avatar
Default bogarts and hoosier qtp question
Ok i apologize up front but i need some help. i have a set of bogart 15x10 15x3.5 and im going with hoosier qtps. now what i cant figure out is what size tire to get this will be mostly track only use. i have a 98 camaro with strano springs. Can i fit a 28x11.5 or a 27x11.5 with minor fender work. Also front skinnie recommendations would be great. i don't know much about drag setups.
i have 3.90 gears m6 9" looking for the best size for my application. about 520hp n/a no 1/4 times yet.
Old 09-09-2009, 11:36 PM
SJM Manufacturing Inc's Avatar
27's will fit and shouldn't need any mods. Once you go larger, its pot luck. More than likely you'll be modifying something to make 28's fit. Adj. LCA's and PHR's are a must for the 28's.
Pick either mtt-1573 sportsman or an ET drag of some sort. Do NOT use a VW radial or other radial front tire for the wheels.
Good luck!
Old 09-10-2009, 07:23 PM
WS6 SRT-8's Avatar
I have almost the same setup as you. I used the MT Sportsman fronts #1573. I have QTP 26X11.50's on the back. The 26's seem to work well with my 3.89 gears.
Old 09-11-2009, 10:25 PM
Brasshead's Avatar
28" Mickey Thompsons on Bogarts fit my '98 but I did roll the rear fenders.
Quick Reply: bogarts and hoosier qtp question
