Which M/T radial for my combo?
I have a '99 T/A with a 6.0 w/ L92 heads, custom cam (around 612 615 lift), bolt ons, etc. It has a built A4 with a FTI 4000 stall....but only 3.23 gears. It dynoed at 413 rwhp and 435 rwtq. I don't really want to change the gears either due to the fact that I will be hosing it down with a 150 wet shot to get it moving. Anyway, on a set of 15 in. summit stars, should I go with the 275 60 M/T drag radial or the 275 50?
P.S. It is at stock ride height with non-adjustable lca's and weld-in frame connectors. Thanks for your input.
