quick question
Old 04-07-2010, 07:03 PM
02ws666's Avatar
Default quick question
at the end of the month i am going to widen my stock speedlines
im on the fence of how wide to make the 2 back rims
i will be running 315 nittos untill i get a dd which wont be for a while, then i will switch to some et streets
should i widen them to 11inches or 10.5inches?
also, what else will i need to get them to fit? stock suspension. do i need a spacer? i heard a 1 inch spacer is needed? where do i get this?
any other information that i will need plz feel free to let me know.
thx guys
also if your int he dfw area i might just be obliged to buy you a beer
Old 04-08-2010, 12:36 PM
02ws666's Avatar
bumpity bump
Old 04-08-2010, 12:43 PM
Eskimo's Avatar
I'd go at least 11, if not 11.5 or 12 (which would then let you run 335's if you desired).. the wider the wheel, the better the contact patch...
an adapter (bolt-on spacer) will be needed..
Old 04-08-2010, 01:44 PM
02ws666's Avatar
well i only plan on 315s cuz im not going to track the car.
where do i get a spacer and how big?
