Jegs Sport Star 2 Rims Help
I searched all day on these rims and came up with nuthin I know I want to do 15x4's up front and 15x10's in the rear and I know all about having to do the BFH mod so I just wanted to know what bolt circle #'s and offset #'s I need. If anyones knows of a direct fit size also (no caliper grinding or spacers) that be cool to, thanks
I don't know if you need to run a spacer up front with the 15x4s, you most likely will though.
As far as backspacing goes, you need 7.5" for the rear wheels. 5x4.75" bolt circle. Also not sure about the grinding for the rears, I would say you most likely will have to, probably just a little bit though. You're not going to find any direct fit 15" wheels for our cars cheaper than the Race Star Industries wheels. If you can afford a few bucks more, I'd go that route. $740 shipped with lugs included from jimsracingtires.com. Plus those use shank style lugs which are safer for drag racing.
