Weld Pro-Star 15" -- Spacers? Longer Studs?
Old 01-21-2004, 12:16 AM
tux2112's Avatar
Default Weld Pro-Star 15" -- Spacers? Longer Studs?
I want to run some 15x10 Pro Stars in back.. however if I can avoid grinding my calipers that'd be great...
so.. if I run these 15x10 in back and get longer studs can I run a spacer + these wheels w/out having to grind the caliper?
Also what size studs should I look for?
What size spacer?
Also... are there any instructions out there on what needs to be grinded to make them fit w/out spacers?
Thanks
Old 01-21-2004, 09:33 AM
LS1Tech Co-Founder
Nine Ball's Avatar
It would be impossible to run the 15s without grinding the calipers. The ones that fit on our car already have the maximum rear backspacing, and if you used a huge spacer to move them out, they would stick out that much. Plus, thick spacers are not safe.
You need a 15x10 wheel with the 7.5 backspace. 5/16" wheel spacer, and a disk grinder. If you take your time on the grinding, you can make it still look nice and you can polish the ground area up.
Tony
Old 01-21-2004, 09:56 AM
WILWAXU's Avatar
I suggest getting a set of Bogarts.
Don't require grinding, and look much better IMO.
Steve @ SJM can get you a good price on them >>---->
Old 01-21-2004, 10:04 AM
Big Mike's Avatar
May I suggest what WILWAXU suggested.
Old 01-21-2004, 10:17 AM
kp
kp's Avatar
Here is a pic of one of my rear calipers off the car ground to fit with no spacer, its not hard to grind them just a little time consuming. FWIW I ground these to fit 15x8 rodlites, 15x10 draglites fit just fine but I didnt want to pound in the inner fender by the bumpstops so I went back to 15x8 draglites and they needed more grinding to fit.
Old 01-21-2004, 10:41 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
If you want to avoid grinding you should stretch up and get the pricier Bogarts.
I run 15x10 Pro Stars in back and did a lot of grinding.
I would never run spacers in back, my chassis guy is dead against it.
Quick Reply: Weld Pro-Star 15" -- Spacers? Longer Studs?
