Can I install et streets that were screwed to rims without screws on different wheels
Just as the title says.
There are a set of et streets for sale that I would like to buy but they have been screwed to rims. Is it possible for me to take these tires and put them on my different rims without screws?
I don't see why not. As long as there not damaged. I would run tubes though cause they will probably leak at the wheel. Then you would probably run screws so you don't shear off the valve stem. If you don't make alot of power and are not worried about spinning the tire on the wheel, then go for it. Remember tho, saftey first.
