best street/strip tire&wheel???
i have a 98 ws6 TA... has lt headers, ms3 cam,ls6 heads,ls6 intake, ported tb, 3500 converter, and a 150 shot!!! im gonna be racin a lot on the street and some on the track really dont know what set-up to go with... and my suspension is not set up either... so if u dont mind tell me a good set up i would really appreciate it... o and i have 18s in the back and 17s on front
Restricted User
Some 315 nitto 555r dr's should help you hook pretty good and have pretty good tread wear. If I can get my wheels widend I am going to get those. Alos for suspension, get some lca's and lca relocation brackets. Those are saposed to help launch alot and they are pretty cheap. Like $190 for both.
Captain Double Post
I run a ms4,150 shot ,4.30 gears ,I roll a drag set up,its not bad on the street at all just be easy on the brakes and turns and its fine,15x4 15x10 with g force drs,hooks good on the street mts are the best but they wear out fast,pretty much by the end of summer if you race a lot you will need new ones and at 190 something a tire it gets pricey
That looks like our road race wheels. Much stronger and more durable than a street/strip combination.
If you want a street/strip combo, that normally is done via 15's but there are a ton of variable as to what the end users goals will be. Give us a call if you have questions or concerns regarding any of our Bogart designs.
Steve
Mechanical Engineer
SJM Mfg. Inc.
724 478 5580
Steve
Mechanical Engineer
SJM Mfg. Inc.
724 478 5580
1 Post
+1 for Bogart and SJM...
Ill ***** it out some more...I wanted a street/strip set up..so I did 17x6s and 15x10s..PERFECT IMO.. Ill prob order some 17s for the rear oneday but I kinda like it how it is!
