offset questions?
Old 04-04-2011, 04:55 PM
Bad98SS's Avatar
Default offset questions?
i want to get 17x11 with a 50mm offset and put 315-35-17 mt drag radials on them. I have the stock ride height. Will these wheel stick out any further from the body than my stock 17x9.5, 275-40-17 set up or will it look the same? thanks
Old 04-05-2011, 05:54 PM
Customizing Director
MadIceV8's Avatar
Yes they will stick out more than stock. With that offset it may still be slightly tucked into the fender, if not flush with the fender. Do a search, you should be able to find photo's.
Old 04-05-2011, 06:16 PM
Deviant LS1's Avatar
A 17x11 with a 50mm offset will be just about flush with fender. It won't stick out.
Old 04-05-2011, 08:06 PM
sakrafice's Avatar
not to jack the thread or anything but im in the market to get 17x11 for the rear of my ws6... i presume where talking about a camaro, what would sit flush or close to flush for the tt2? still 50?
Old 04-06-2011, 08:21 AM
Xsta Z 28's Avatar
11" AR TT2 is only available with w 46 mm offset.
