back spacing help!!
back spacing help!!
i need some help. Going to buy a set of slicks and skinnys, but i dont know what backspacing i will need. if i have to use spacers, that is fine. i am going to use all stock brakes, and i have a moser 12 bolt that is NOT narrowed.
Some help would be awesome. Any brands of rims you would recomend too. i drive the car on the street ocasionally and i dont care if the rims are "off road use only" the cops can kiss my ***.
Location: Your girl's back door giving her the long stroke while you're at work
If you don't want to grind go with the Weld RTS series. They fit front and rear with no spacers
You'll want a medium pad height on both 15x4's and 15x10s(7.5" backspacing). Not sure what backspacing the guys are running on the fronts
