Question about getting an front end alignment to prolong life of tires....
Ok I have a 05 a4 goat running stock oem bf Goodrich gforce 17 inch tires. Now the rears are good almost new shape, but the fronts are getting down, the middle of the tires are ok for couple more months or so but the goat needs a front end alignment because the inner edges are worn bald basically and any longer it might be really bad and show strings and stuff.
So do I just take the goat to a tire shop and like any other car tell them it needs an alignment or do I need to disclose anything special about our goats in getting an alignment done right? Thanks
1 Post
^ 2x on that. Just go in and tell them what you need and they will either take it from there or have you pull it in the bays. But I would ask around and some friends about which tire shop is better/best in your area.
