Help: Will my setup clear the Weld RT-S 15"?
I am planning on purchasing Weld RT-S 15x4 with 1.5 BS (F) and 15x10 with 7.5 BS (R) for my 02 camaro
My car has a C5 brake installed, Currently I have a Torq Thrust II Wheels and I did some grinding to the front caliper and a spacer so the tt2 can fit and it did fit ok but the clearance space is very small (about 1-1.5 mm)
So if I will put the RT-S 15x4 in front will it fit or no. Or do I have to do more grinding
your help is appreciated.
Thanks
Thanks
My guess is that the 15" will NOT fit. I imagine your TTII's are 17" right? That's a big difference. If your TTII barely fit, I have a hard time believing your 15 is going to clear. I guess you'll know when you get them. Good luck, and keep us updated on what you find out.
Brad
Brad
