315 tire availability?
Old 04-24-2012, 11:53 AM
robertbartsch's Avatar
Default 315 tire availability?
....I threw on 4 of these a couple of years ago and they may need replacement in a year or two.
Are these size tires still being sold? I think this size is used from the factory on the front of the Dodge Vipers; right?
Anyway, last time it was not easy to get these.... searched for weeks...
Old 04-24-2012, 11:55 AM
Ellsworth's Avatar
315 are EVERYWHERE
probably the most common tire width for anyone with aftermarket wheels.
Old 04-24-2012, 01:14 PM
MasterTomos's Avatar
On what size rim?
Old 04-24-2012, 01:26 PM
.....these are new rims in stock diameter (18s??? for a 99 SS)..... the rim widths are 10.5 and 11 inches for front and rear, respectively, I believe. The front rims have a non-stock offset, I believe.
...the front tires made the biggest change in performance..... luv them...
Old 04-24-2012, 02:05 PM
LS1HIGHLIFE's Avatar
315/35/17 or 315/30/18? The 18s are harder to come by unless you want to spend some $$$ on Michelins, Pirellis, or GYs.
Old 04-24-2012, 02:58 PM
I believe these tires are mounted on 17" rims....
Old 04-24-2012, 03:04 PM
oem rim sizes on an SS coupe would be 17x9. Definitely not 10.5 or 11 wide. The oem tire size should be 275/40/17.
