offset question
offset question
ok so i have read the sticky on this but am consfused. as it states that a 18x10.5 will not fit with a 56mm offset in the rear with out the BFH mod. but i called OEWheels and asked them about one of their rims and they said they will fit no problem.
my second question is that i currently have 17x9.5 on all 4 corners, and i will be stepping up to a 18x8.5 up front and 18x10.5 in the rear. here is a breakdown of what i have:
17x9.5 (56mm offset) up front w/ 275/40/17.......going to 18x8.5 (46mm offset) w/ 245/40/18
17x9.5 (56mm offset) out back w/ 275/40/17.......going to 18x8.5 (56mm offset) w/ 295/35/18
my question is will this make my rear wheels stick out 1/2" more on either side being it is the same offset? so basicly if i bolted the old rim on one side and the new one on the other side, the new rim would be 1/2" closer to the wheel well, and would stick out 1/2" further from how far the old rim stuck out?
next question am i gonna have the same clearance up front for calipers on the front, and will the outside lip of the new rim sit in the same place as the old one? will the rear and front be level with each other or will the rear be sticking out 1/2" more?
i ask about the front cause i know that my current rims (these):
http://www.oewheelsllc.com/Wheels_3/...ro_4/C6-Z06_11
but i have them with a 56mm offset
and the ones i am going with are these:
http://www.oewheelsllc.com/Wheels_3/...Wheels-Black_3
i am also going with the smaller rim up front so i can run a 245 tire for better stability on the freeway.
also anyone with these rims or even someone with the same offset and size rims (dont have to look like these, just size and offset have to be the same) i would love some pictures for examples. on T/A's or Birds if possible.
17x9.5 (56mm offset) out back w/ 275/40/17.......going to 18x10.5 (56mm offset) w/ 295/35/18
Hope this helps.
