Please help me!!!!
Please help me!!!!
I just recently put on a set of 15" fat and skinnies on my 01 ss, now my brake light abs light and my asr light are always on and the braking is shifty, what can i do to fix this???? Thank you Ls1....
If they are over 3/4" difference or so (Maybe less, maybe more, not sure specifically) of stock it will trigger the lights. As far as braking, only thing I could think of would be due to drag radials or slicks that you put on there. More info about your setup would help.
Not sure what you meen by a abs brake fade. If you meen abs is activating well I am sure it is. If you are not sure if it is abs then I would pull the fuse for the abs In the under hood fuse box and drive it. With the abs deactivated you have the regular brake system. Personaly I would not drive on the street with small front tires but that is your choice.
