2" adapters
Old 04-10-2013, 04:20 AM
nogo68's Avatar
Default 2" adapters
Going to order my S60 soon, and would like to narrow it a couple of inches for my drag setup. I just put new 18x10.5 C5's. Is it safe to run a 2" adapter for a street car that will be driven on the highway.
Old 04-10-2013, 07:57 AM
buellxb12s's Avatar
I run 2.5 spacers on my truck for my anniversary wheels. it's my daily driver with no problems
Old 04-16-2013, 11:12 AM
93BlackBeast's Avatar
Same. I had my 9" narrowed 2.5" per side and ran an adapter until I had my new wheels ordered. Just be sure and run "adapters" and not spacers. Spacers refer to just longer studs and a plate to space the wheel out. I went with adapters that bolt to the hub like a wheel itself and then offset the new bolt pattern. That way, you can run a different pattern if need be but for our case, it'd be the same both patterns.
I've got my 2.5" set still if you would like to pick them up cheap. Just let me know.
Cody B.
Old 04-16-2013, 05:43 PM
TruBloodTransAm's Avatar
Cody B.
Pic?
Old 04-23-2013, 08:36 AM
69TA's Avatar
yeah i used to run them on my MWC narrowed rear and they were fine
just make sure to use aftermarket studs and not the crappy GM ones
Quick Reply: 2" adapters
