I have a 99SS WILL 1inch spacers fit c6 19x10 rear
Installing c6 corvette rims on my camaro will a 1inch spacer work???!! Or does it have to have a 1.25inch?!!
I have an 01 Z28 and was running a 1.25" with c6 19x10's. They rubbed the fender lip on bumps. I just put on some 1" adapters instead and no longer hit the fender and it runs great. If I take a turn real fast they rub just a little, but I think its the inner fender area near the lower control arm that is rubbing. That can be hammered in pretty easily. I'd recommend 1" but I have some 1.25" sitting in the garage if you wanna buy em. FWIW
So these are the spacers I went with for my 19X10 C6 rims, I did not need shave the lug nuts down because the OEM C6 rims have an indentation in the back. If your after market deep dish rims, and the rims dont have the indentions on the back side than you will have too shave your lugnuts down a 1/4 inch or so. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251130504990
