Corvette wheels on a third gen
Old 04-21-2013, 11:09 AM
trevmust's Avatar
Default Corvette wheels on a third gen
what kind of spacer is needed to do this safely and properly?
Old 04-21-2013, 01:10 PM
Marc 85Z28's Avatar
That depends upon the what Corvette wheels you have.
Old 04-23-2013, 06:04 PM
scottyroc's Avatar
It depends on the size which was already mentioned. The fronts usually need a 2 in spacer if going with a standard 4th gen size wheel, 17x9. If you have a stock rear you will also need a spacer of 2 in if going with the 17x9 rim. You could possibly use a 1.5 in spacer in the rear. If you have a 4th gen rear in the 3rd gen then no spacer needed for the 17x9 wheel since the rear is a total of 4 in wider.
Quick Reply: Corvette wheels on a third gen
