Wheel Spacer vs Adapters - Questions?
Old 04-23-2013, 09:47 AM
No Juice's Avatar
Default Wheel Spacer vs Adapters - Questions?
So I understand that its preferred to run a bolt on adapter rather than a spacer which would likely require longer studs.
The smallest adapter I can find is a 1", but I only need about a 1/2". I know some guys are running the 15mm spacer with longer studs but I would prefer to have the bolt on adapter for the added strength.
Is it possible to mill the 1" adapter down? I don't have one to look at.
Old 04-23-2013, 10:14 AM
carlos64030's Avatar
http://www.hrsprings.com/products/trak/
Old 04-23-2013, 10:50 AM
No Juice's Avatar
So it looks like I can get a bolt on adapter in 20mm ?
Comes with short lug nuts and new studs.
It doesn't say it specifically, but isn't DRM style a hubcentric as well?
Old 05-06-2013, 09:06 AM
WS.666's Avatar
Get longer studs from ARP.
Old 05-06-2013, 09:20 AM
GMRACER13's Avatar
20mm is over 3/4". Just get longer studs and 1/2" spacers.
Quick Reply: Wheel Spacer vs Adapters - Questions?
