Wheel Weights on Convo Pros
Hoping someone has had some experience with this that can confirm.
I picked up a set of Convo Pros to put on my TA with stock calipers. I test fit everthing and nothing interferes just like I have read.
Now I want to get a new pair of MT Street Radials mounted to the 15 x 9s (6.5" bs) but my concern is that the stick on wheel weights will hit my calipers in the back since there is minimal clearance now.
My question is did you have this problem or how did you prevent it? My thought is to mark a line inside the wheel that will clear the caliper and only put weights up to that mark. What I worry about is that it will not give me enough room since every MT tire I have ever had mounted required a ton of lead to balance it.
