weld prostar questions
I use 3" long studs with my Prostars. Weld says the wheels need 1.310'' Mag Shank lug nuts. If you want to run a closed end lug nut than I'd get 2 1/2" long studs. I use the long shank open end lug nuts. I have Moser screw in 3" studs and Moroso 3" screw in studs on my car. The Moser studs stick out the end of the lug nuts by a thread and the Moroso's stick by a 1/4" an inch.
