Can summer tired be used in cold temperatures
You can, I've done it and even driven in snow. They turn into rocks do to the temp so you will feel the road more, and traction will suffer as well since they cannot get up to temp.
So you wont explode into a million pieces...
my car can barely even make it up my sloped the driveway on summer tires, involves 2nd gear and trying to keep it off the rev limiter..
my car is summer driven only I just pull it out of the garage some times to work on other cars. its been -20-30c here lately..
My NT555s are okay... as far as summer tires go they're not that aggressive though. I have driven them in light snow and it was sketchy but I made it. As long as there's no snow on the ground it's fine, just don't go nuts. They do feel 'lumpy' for a while before they get warmed up.
Captain Double Post
my 28 inch drs have no grip when its cold , i wont even take my car out wgen its cold with wet roads or snow, your just asking to end up in a ditch ir worse, but cold n dry i can drive it no prob just getting on it will spin them almost at any speed, ill say this if its your dd, pick up some crap rims with good winter tires n have a set for summer, i couldnt even think of driving my car all winter,i wouldnt get anywhere and be stuck every 3 feet lol
Probably different for different summer tires. I drove my car with kumho spt tires day before yesterday. If I had to come to a stop, when I tried to get moving again the tires would just spin. It was very bad. At one point the trans shifted and the *** end just came around. Luckily I was on an empty road and only doing 20mph.
Decided not to drive it again until it warms up some.
Like other have said, it's OK to do but be very mindful of what you are doing.
It honestly feels like I have 500hp on NT555 315's on my exhaust only 95 Z.
EXPECT poor traction, drive accordingly. Even taking turns quickly the rear end walks out on you quickly.
I was between a rock and a hard place so I was forced to use these Nittos this winter. I also run two 60lb sand bags in the trunk
LS1Tech Platinum Sponsor
Some very soft summer tires can actually crack under cold temps. An in example of this is the tires that come on a new ZL1 Camaro the Goodyear Eagle F1 Supercar G2. These have cracked and they are not covered under warranty.
The majority of summer tires do not crack under cold weather but do get hard and loose a lot of grip. You will have much reduced traction and grip.
