02 fbody 3" narrowed rear and stock ws6 rims?
You would either need to run really long spacers, or have the wheels widened. The latter would probably require mini tubs.
If you want to run stock wheels, run the stock width rear axle IMO.
Is it possible to make them fit - Yea. Is it possible to survive by drinking your own pee - Yea. Should you do either - No.
It would take some doing...but it can be done....some wheels with the right offsets would probably be cheaper....
In your case it would be basically swapping inside and outside lips....creating a new offset....might as well make them wider than 9 inches too...
https://ls1tech.com/forums/texas-mem...eels-done.html
