17x9.5 fronts 18x10.5 rears Help
#41
Stroked383Hsr where did you buy your wheel adapters from and roughly how much were they if you don't mind me asking. I'm seeing a lot of mixed reviews on brands and would like to know what you are running to give me some piece of mind. The adapters are the last piece of the puzzle I need and I'm stressing over these adapters.
http://www.ebay.com/itm/2-Pc-Camaro-...3D262403961838
just look for their 1" spacers in black and your good to go
#42
I have a set for sale that are the same other than mine have the small cosmetic rivets ... they are 18x9.5 w275/35 fronts and 18x10.5" w295/35.. they will fit up front no issues... rears will need a bit of BFH persuasion or cut the small sheet metal flap/piece down by the lower control arm where it meets the car... will not need to roll the lips and the bump stops only rub if the suspension is hanging... under load at ride height they clear...
