Weld Draglite XPs
I believe those would fit directly.
They are very heavy, almost all of the benifits of running a drag rim is nullified. Unless your purchasing them if you like the way they look and not for performance gains, just stick with your stock rim. That rim is very narrow (unless the class of racing your running in states you can't use more then a 10.5 tire. You need a 10 inch rim for an 11.5 wide tire.
I do like the way they look better then the economy rims.
Steve
Steve
