15x10 w/ 5"BS ?
15x10 w/ 5"BS ?
I currently have 17x11 TT2's with( I Think) 7-3/4 BS that fit in the wheel well perfect. My ? is i'm going to a 12 bolt that will be narrowed 2" on each side. I want to put some 15x10 w/ 5" BS out back. Will they stick out of the wheel well and if so how much do i need to narrow the rear for them to not stick out (sit flush)?
ThankYou,
Moz
ThankYou,
Moz
Well, on a stock width rear end to use a 15x10" wheel you have to use one with 7.5" BS. So, that being said with a rear end that is narrowed 2" on each end you will need a 5.5" BS. So, to run a 5" BS you will need to narrow the rear end by 2.5" on each end.
Chris
Chris
Man thank You for the reply 1 BAD GM! I didnt think anyone was going to help me think this one out. Just to be close i told my rearend builder to go 2.5" on each end before even seeing your reply this evening. Looking to throw BFG DR 325-50-15 on a 15x10 rim. My car is not going to be lowered so im hoping that itworks out?
