Can I move the 18x10.5 58mm offset up front and use smaller tires up there? and....
I've been running on the 18x10.5 315/30/18 with a 58 mm offset now for a few weeks. and I don't have any rubbing issue unless I cut a corn at like 60mph+ like under heavy load then I hear something that kinda sounds like grinding metal. I'm not quite sure what it is. Because I don't see any marking anywhere.
Will the 18x10.5 58mm wheels fit up front if I use a smaller tire?
I'm considering ordering another set of 18x10.5 with 50mm offset of like a 46mm offset..
I figured if I move the wheels(18x10.5 58mm offset) up front put on 295s then put new 18x10.5 with like a 46mm or 50mm offset and use my current 315's in the back that it would make them fit better. Am I right by assuming this?
Originally Posted by Xsta Z 28
It's going to be very tight up front, I have heard it done though.
I have put the OEM Z06 18's in front.
I was toying with the idea of 18's all the way around.
The tires were 295/35/18.
The only place they rubbed was at full lock when backing
out of a driveway or something. There was a wear
mark on the black inner fender liner at the very front
right in the middle. About half way from the outside
of the car to the inside. I would say about 8 inches in
from the outside of the car.
I drove with the 18's in front on freeway ramps at 55mph, which
is the max I can, if I go any faster, tires start to howl. Next
thing you know I would be in the ditch, but I keep it at 55 and
lower. I drove around like that fro 2 weeks. I drove my normal
routes(to and from work) in my normal manner. I also did some
EXTRA 'test' driving in a large parking lot. No cars around.
I did a "g" test. Just drove in a circle of about 100 feet diameter
and drove until I spun out. Both in a left hand circle and right hand
circle.
There was no rubbing at all. The only place there was
any mark was where I was describing it. I keep my car VERY
clean. there were no tire/rubber marks anywhere on the
"rear" part of the wheel well.
I wanted to do 295's all the way around so I could rotate the
tires to get a little more mileage out of them. But I soon
scrapped that idea once I did H/C and found out traction
is a problem. I will be getting Drag Radials when my rears
are wore out.
I have the OEM Z06 265/40/17 up front. I plan on keeping
it thant way.
I say you will be fine.
circle.
are wore out.
it thant way.
circle.
are wore out.
it thant way.
circle.
are wore out.
it thant way.
Howling, starting to lose traction that's all.
I was on an ON-RAMP. Those that are a "circle"
to go from a city road onto the expressway.
So I was in a turn entering the freeway.
Normal traffic on the ON-RAMP is 35mph.
That was my "test" for a high speed turn, that's all.
Nothing wrong with tires. I just wanted you to
know I was "pushing" the suspension, weight transfer, whatever
to see if the wheels would rub under "extreme" conditions.
I did NOT just bolt them on the front and drive 100 feet
down the road, then tell you they are fine on the front.
I drove them through a little bit of a "test course".
PM me if you want any more information.
thanks
thanks
thanks
thanks
