Got Draglites Mounted....without grinding???
Old 02-23-2005, 07:06 PM
The LT1 That Could's Avatar
Default Got Draglites Mounted....without grinding???
....for the most part. This is on an LT1 car. The right rear rubs noticeably on a test drive and the left scrapes the caliper in only one spot. I am somewhat concerned as to why they fit this esily. Could it be because the rear pads are worn down so much, or is it just easier to fit a 15x8 (5.5bs) on the LT1 rears???
thanks
Old 02-23-2005, 10:03 PM
WickEdSix98's Avatar
They should clear easier because the LT1 brakes are smaller. If the pads are worn a lot that may cause interference later when you put new pads. I'd grind them a little extra just in case of that.
Old 02-24-2005, 12:28 AM
DietCoke's Avatar
They take minimal grinding, but you do need to grind the front of the fins around the corner off. Its just brake pad wear, new pads and they'll touch all over.
Old 02-24-2005, 09:37 AM
skimms98's Avatar
why would you have changed them when it looks sooooo P I M P in your sig on the Telstars???
Old 02-24-2005, 05:55 PM
ha, thanks man. I just kinda wanted to go with draglites for some reason. something new i guess. The telstars were pimp tho! lol
Old 02-24-2005, 08:45 PM
The Guy in MY 99TA's Avatar
My draglites never rubbed on my buddies 94 z28 even with new pads you shouldn't have any problems.
Josh S.
Old 02-24-2005, 09:13 PM
hopefully i wont have to....they sure do look good tho. with a good polish they much more bling than the telstars. will be selling those this weekend, and ordering the front draglites and then replacing the nittos w/ a set of Hoosier QTPs!!
Quick Reply: Got Draglites Mounted....without grinding???
