centerline problem
centerline problem
Ive recentally picked up some centerline auto/drag style 05 15x3 1/2. When I got them I knew Id have to grind on the calipers some.Ive had welds on there before(A friends) and grinded the calipers so they would fit.Ived tried spacing out the rim with washers to see want size wheel spacer and longer studs ill need.Ive got about a half of a inch of spacers on it now and dont want to go any futher so the tire does stick out of the fender.Any ideas on how to make this work?Im not getting new brakes.
Somebody has had this problem before.As many F-bodies as Ive seen in the mag's running skinning's in the front.There's got to be a fix!I see that H&R Springs has some sort of wheel spacers that might work.Anybody tried them ?
