clearance with 295/35/18 in back
I just got my new wheels and tires in and i'm wondering if i'm gonna have clearance issues in the back with my 295/35/18?? I will be lowering it shortly as well and will that create problems?? Thanks guys.
Originally Posted by oodahss
anyone??........................hmmmmm............ .........
Depends entirely on your wheel offset.............seriously. You need to post that before anyone can answer. The ZO6 wheels are tucked into the wheel well so much that you might have inner fender rubbing when lowering. Many people run wheel spacers in the rear to push the wheels out further to prevent that and to loose the overly tucked in look. My 295/35/18's fit great and I'm lowered 2" FYI.
i cant remember my offset, i think it was 44mm on 9.5 deep wheels..i actually did need to SFH (Small Fing Hammer) mod my passenger side cause it rubbed on hard corners. Im lowered on a pro-kit
i just put on my 295/35/18 in the rear, and they are rubbing real bad , because i am lowered i guess. tomorrow i will have to see if i can bang out the innere fender a bit to make for some clearance but i will also probably have to get a little bit of a spacer too.......
i put the wheels on with 8mm spacers in the back and they don't stick out a bunch, I really like the way they turned out, i'll try and get some pics.
No clearance/rubbing issues at all with the outer quarter lip rolled flat.
I have a good 1/2" to the outside and over 1" on the inside, like stated earlier it all depends on the offset of the wheel.
Has anyone compensated for zo6's when getting a new rear -?
Like order a 9" 16mm wider. I'm getting 11" rims w/ a zo6 back spacing and am also in the market for a new rear. Thought that might be the ticket.
http://www.ls2.com/forums/showthread...hreadid=225761
my car isnt lowered yet but im putting the same rims (18x10.5 58mm) on soon. I was thinking of getting arp studs and a .5 inch spacer. I see all the spacer measurements done here in mm. Is this going to do the trick? Oh and btw i don't want my car to have the wheels sticking out like snoop dogg's lowrider
