what size can I fit?????
I want to get some draglites for the front (not skinnies) cause I have the rears on.
I was looking to fit a 15x5 or 15x8 on the front.
What B/S do I need. And what size spacer?
I know I will have to grind the frt caliper, but I don't want to grind more then needed
15x3.5 on the front. You can't fit a 15x5 or 15x8 on the front. 5/16 spacer if you don't want to grind, but you'd need longer studs for safety. I'm using my stock studs with the spacer until I do some more grinding this afternoon.
