60' times with 275/40-17 MT Drag Radials??
Old Drag Racer
I know the 15 inch versions hook like mad or so I've read but I don't see a lot of talk about the 17 inch versions. I'm going to try a set of these on my stock 2000 SS rims and am curious as to what kind of 60' times I might expect. My car is mostly stock putting down 308 to the tires through a Moser 12 bolt w/3.42 gears. This was with a Yank PY3400 converter though I've recently switched to a PT4000. I know there's no way the 17" ones will hook up anything like the 15" versions but I'm curious at to what kind of 60' times everyone was getting while using the 17's. If you're a manual car, I'd like to know and if you're an auto, I'd sure like to know which converter you're using and what rear gear. Thanks everyone. BTW, I've cut 1.8 60' times on brick hard regular radials so I'm sure hoping to better those times with the MT's.
