Will these fit?
Will these fit?
Im just wondering if these 18x9 5x120 with a 38mm offset wheels will fit our cars?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275
10.0" ... +38 to +48 mm .... 265, 275
The bolt pattern is technically incorrect, since the F-Car is 5 x 120.65mm. The difference is very small, and the wheel most likely would not be hub centric.
Will the bolt on? sure will . .
Will they stay on? I have heard of issues, but I've heard of many run with no issues.
IMHO? I'd run a wheel tire combo built for the F-Car. Your wheels and tires are the only 4 things keeping your car shiney side up.
Many wholealers will actually drill the correct bolt pattern into the wheel. I just purchased a set of alba monaco's that had both 120 and 120.65 drilled onto the same rim.
Good luck
Good luck
