Whats needed along with 315's??
OK, OK, so Im lazy! but I have done some research....
So yeah, I want to get TTII's in 315's on the back just like everyone else. What parts would I need, and/or what parts do you think I may need?
Obviously Im getting lowering springs and a panhard bar (could you get away without one?) And do I need LCA's? and spacers for the wheels or no? Just fill me in a little bit, Im not to savy when it comes to suspension and wheels. THANKS
a hammer.
I had 315/35/17 Nittos (a tad smaller than a radial 315) on my Eibach lowered car and I had no trouble with them. Just put them on with the rear suspension loaded. And make sure you get a 50mm offset wheel
Adjustable Panhard Bar to properly center the rear, grind the corners of the bumpstop brackets down so they are radiused (do not remove bumstops), and a BFH for the inner fender well as stated earlier.
This is all you need to have them fit on a stock height car - don't know if the car is lowered...
