Stripped wheel stud....
I have a stripped/cross threaded wheel stud on my rear, 1 of the studs won't let a lug nut tighten on it at all. It started rounding off the insides of my Weld Racing lug nuts, and is really pissing me off. I hear you can't remove the wheel studs in the rear without removing the axles. Is that true? Or since I'll be replacing it with a stock sized stud, can it just pop out?
