front runners?????
Old 07-31-2006, 12:27 PM
BLACKDEATH's Avatar
Default front runners?????
i have a 96 camaro with 15in weld prostars on the back but i want front runners......what size will fit with the least amout of mod? can i run the 15 in front runners welds?
thanks.......
Old 07-31-2006, 12:49 PM
BAIN's Avatar
15x3.5" with 1.75 BS is what most run. You can either grind the front calipers for them to fit or run a 5/16 spacer. I would suggest longer wheel studs if you are going to run a spacer.
Old 07-31-2006, 09:59 PM
BLACKDEATH's Avatar
cool thanks, i heard its really hard to run the 15 in in the front but i cant wait to get them.......thanks alot ill let you know
Old 07-31-2006, 10:03 PM
LS69TA's Avatar
Since you have LT1 brakes, you may not have to do much to fit them, seems like I've read that the Welds fit better on the LT1 brakes.
