C6 ZO6 Offset Tomzwheels
Old 08-03-2006, 03:39 PM
Phoenix WS6's Avatar
Default C6 ZO6 Offset Tomzwheels
Looking at purchasing a set of 4 18x9.5 from TomZWheels. He has them with a +40mm offset and a +50mm offset, what's best for an 02 WS6?
Also, what's your opinion on the HTRZ 2 tires? Will 285/35/18 all around fit? I think they should fit fine out back, but will there be any rubbing issues up front?
Thanks in advance.
Old 08-03-2006, 07:09 PM
02perfect's Avatar
Default 295 35-18's out back............
and no probs. i'm think there would be an issue with a 285 up front, depends on how low u are. may limit turning radius.
check my sig, click on "my 02 ss" for info on my set-up. it seems to be pretty common, size-wise.
Old 08-03-2006, 07:47 PM
Thanks for the input, I'm lowered with the pro-kit. So that's why I was worried about front rubbing in turns.
Old 08-03-2006, 10:27 PM
wabmorgan's Avatar
I'm running P285/35/18 all around. Car isn't lowerd but I have no rubbing issues and the frount is alreadly pretty low. If I do lower it... it won't be by much. .5 to 1" at most.
