MT ET Street radials **thumbs up**
Now that I have a 395 stroker traction has become quite an issue. My prior combo was full exhaust, bolt-ons & TNT 100shot on 315x35 Nittos. At 22psi I could hook the car on spray in 1st gear (street). Since switching over to the bigger motor the Nittos just wouldn't hold anywhere in 1st or second at WOT.
I now have the MT ET Street radials and couldn't be happier. The car will DEAD HOOK in 1st gear with 25psi, all without heating them up. I'm sure with lower psi and a lil heat these bad boys will handle a nice clutch dump. If you're on the fence for tires and want the best of both worlds these are the way to go.
Suspension = SLP Eibachs/Bilsteins, BMR chromoley adj everything
PS Got them through RPMOUTLET for $165.00ea + $9.99 (handling charge)
