10.5" rims with 315's...
Old 09-23-2006, 05:15 PM
BrntWS6's Avatar
Default 10.5" rims with 315's...
I'm looking to run a 17 x 10.5" rim on the rear with a 315 nitto DR on a car lowered 1". I know with a 11" rim you usually have to massage the fenders etc. to get it to fit without rubbing. But how much easier would the 10.5" fit, if any. Thanks in advance.
Old 09-23-2006, 05:44 PM
02gixxersix's Avatar
Is the rubbing problem only with lowered cars? I have seen a ton of cars with 315's out back and they all seem to fit well.
Old 09-23-2006, 05:48 PM
flyinglow57's Avatar
yea lowered only because the fender is too close the outer part of the tire..
depends on where the .5" is takin out off. its off the inside of the wheel your not gonna fix anything.. but if you get it so its basically off the outside. like change offset... then your golden.
i would imagine.
Old 09-24-2006, 08:11 AM
BrntWS6's Avatar
anyone else use 17 x 10.5 with a 315?
Old 09-24-2006, 09:21 AM
I <3 80057's Avatar
My 17x10.5's with a 45mm offset and my 315's fit perfectly. My car is also lowered.
Attached Thumbnails 10.5&quot; rims with 315's...-100_0715.jpg   10.5&quot; rims with 315's...-100_0724.jpg
Old 09-24-2006, 11:38 AM
f50nut's Avatar
Are those Sumitomos? They run a little smaller than Goodyears and some others. So do the Nittos, you should be okay.
Old 09-24-2006, 11:41 AM
stevensLS1's Avatar
you will be fine. i ran that exact setup on my mustang with sportlines and it doesnt rub. i have 11'' wheels with 315 bfg DR with sportlines and the fenders are rolled. it rub but not much. good luck
Old 09-24-2006, 03:47 PM
BrntWS6's Avatar
thanks for the replies
Old 09-24-2006, 03:52 PM
911ss's Avatar
im ordering mine tomorrow and my car is really low, i shall get pics asap when they get in...
Old 09-24-2006, 05:15 PM
I <3 80057's Avatar
The TTM's? Chrome? Anthracite? Black? Either way, I want to see them on another car very bad! Post them ***** up!!
Blake
Old 09-24-2006, 05:20 PM
C_Rules's Avatar
Yeah i got the TTMs but i want to run a nitto DR out back. I dont know if the rim will stick out past the tire. If i run a different tire like a goodrich it migh rub. anyone know how much wider a bfg is and if it will rub?
Quick Reply: 10.5" rims with 315's...
