I have the 17x11 zr1s and only when the body is extended from the suspension does it rub the bumpstops. Is there a negative side to removing them like everyone does?? Car isnt lowered at all its at stock height.
I'd try to trim them first. Then if you still need more you could remove them but depending on how low your car is you might want to put something in its place to avoid bottoming out.
